メインコンテンツにスキップ
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
154回答 すべてを表示
Part of the screen does not work
After replacing digitizer the top (assuming home button=bottom) part (about 0.85 inch) for left to right does not respond. What could be the reason? Looks like it is exactly 1/9 of the screen maybe that could be a clue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Were you replacing the digitizer because it cracked, or because of a similar issue on the original digitzier? It could be a damaged connection that caused your initial problem.
Where are you buying the digitizer from? That could make a difference.
さんによる
コメントを追加
2件の回答
bad digitizer.. This is common, right out of the box.. 20 percent are bad, and on some, I have even had the connectors come out separate from the digitizer (yeah it was broken off).. don't doubt what your first inclination is, and don't make it any harder than it is..
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Tried another digitizer with the same result. still could be the digitzier (down to 4%). or maybe something else. do you know of a source that offers good pretested digitizers?
さんによる
Ifixit and MobileDefenders offer great parts with excellent QA.
さんによる
コメントを追加
The left 10% wouldn't work for me first time. Went back and checked the ribbon connectors and managed to get it in another .1mm and also one of the plastic clips needed sliding in a bit after clipping it down. Perfect after that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
boazparran さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 10
今までの合計 740
