メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
White screen after drop
I dropped my iPod and now my screen is white. The iPod still makes sounds, gives me notifications, and the buttons do what they're supposed to.. I can even unlock it by sliding my finger across it, but my screen it just white. I can't see what I'm doing.. Help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Hi
If youve dropped it then its likely the screen has gone faulty and will need replacing.
There are guides on ifixit to help you replace the screen but you do so at your own risk as its not easy.
You can also buy the part from ifixit
Regards
Update
Hi you can pick up a replacement screen for about $30 from ifixit found here
iPod 4G Display
there are plenty of guideas around to assist, but i do warn you its quite difficult if youve never done it before
Regards
The display is a 160x120 pixel 2" LCD screen.の画像
製品
iPod 4G Display
$29.99
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thank you! Do you have any idea of how much that will cost me?
さんによる
About $30 probably if not less
さんによる
コメントを追加
最も参考になった回答
Hello! It may be the LCD is damaged or the connector may have just popped loose. I would follow the guide here to open the ipod up and just reseat the connector first. May save some money. If that doesnt do the trick than I would order a replacement screen and replace. Not terribly difficult to do. The screens usually run about $15-$20 online.
Hope this helps
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Lace さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 2,004
