メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
How to fix problems sending/receiving data?
Brand new Samsung Galaxy S3 phone, won't send or receive data, other than text.
Have tried all of the settings; matched with an identical phone & settings, but this one won't work. Even the data plan is identical.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Hi,
Please you give some more details:
  • What settings have you check ?
  • When you said not data sent/received, is it only for LTE/GSM/GPRS/UMTS connectivity or is it also including Wifi, eventually Bluetooth ?
  • What about MMS ?
  • Which country/operator ?
If everything works but not LTE/GSM/GPRS/UMTS and mayby MMS also, it is probably a APN (Access Point Name) related issue.
*(based on the supposition your S3 is running Android 4.0 or greater, let us know if it's wrong)
First of all just make sure Data is activated (we nerve know!):
  1. Go into Settings menu
  2. Into "Wireless and Networks" section select "More..."
  3. Go into "Mobile Networks"
  4. Here make sure data are enabled and unchecked "Use only 2G networks"
If nothing better at this point:
  4. And finally "Access Point Name"
Here you're gonna have to check the settings according to what your operator require. You can googlize your operator name and with "APN settings" or you can let us know which operator so we can help you about that...
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Gprs,edge tower
さんによる
Awesome, Thank you! All fixed and no where near as long, or as complex, as i feared!
さんによる
コメントを追加
Send/ receive data in rural town but not from my home in the country where I use a repeater or a Quattro signal enhancer
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
onecrazybluesgirl さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 18
今までの合計 13,486
