メインコンテンツにスキップ
iMac Intel 27インチ EMC 2309 (Late 2009, Core 2 Duo 3.06もしくは3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHzもしくは Core i7 2.8 GHz) ID iMac11,1
467回答 すべてを表示
締切られた回答
Logic board lcd connector thin metal cover came off a little
Hey guys,
While replacing the HD on my late 2009 imac i7 2.8g I may have messed up the LCD connector to the logic board.
I have attached a picture (from the ifixit guide) of the part i'm referring to.
Here is what happened. The cover to the connector is in 2 pieces that cover the front of the connector. The right half of the cover came off. If it still connected, however it's lose.
I'm wondering if that is going to be a problem. I hope it wont be but I think you guys can better tell me if i just completely screwed up my iMac or not.
Thanks!
J
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
as long as it works and you are sure the connector will not come off while reassembled inside the machine i think it should be fine.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I'll know for sure if it works when i get home. I'll update in case this happens to anyone else.
Thanks for the response!
J
さんによる
Well... It does seem to work. I'm doing a timemachine restore now.
One of the rubber pieces on the connector came off too... That cable and its connector are horrible!
さんによる
コメントを追加
i messed up with mine today ... i broke some pins on the connector ... i assume that i must replace the hole logic board..
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
or have someone solder a new connector to your board.
さんによる
コメントを追加
APPLE imac 27 inch internal lcd connector FI-X30SSL-HF
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 500
