メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
締切られた回答
How do I remove the camera from the phone?
I received a Galaxy S III (Sprint) for X-Mas, but in order to use the phone at work, I am required to remove the camera from the Samsung Galaxy S III (Sprint). Are there step by step instructions to accomplish this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Ron here is a teardown guide for your phone,Samsung Galaxy S III Teardown, I just changed a Camera in an S 3 and can tell you its fairly easy, the toughest thing is getting the phone snapped apart in the first stage, I had best luck starting at the bottom and working to the top, good luck, If this Answer is helpful please remember to return and mark it Accepted
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 3,081
