メインコンテンツにスキップ
PlayStation 3 (PS3)はソニーコンピューターエンターテイメントによって製造された3世代目の家庭用据え置き機で、PlayStation 2の次世代機となります。これらは2006年11月11日に発売されました。
781回答 すべてを表示
締切られた回答
YLOD (After using kit)
Hello there,
So I had my power flicker the other day, and later that day the ps3 played a movie for about 20 minutes then turned off.
I was then getting the issue where it powers on, yellow light, then red. And then the red light would just blink.
I bought the YLOD kit and followed it to the letter. My PS3 doesn't have the memory card reader so it was slightly different but I got around it.
Afterwards, I booted it up and it came on! I was so happy, I ran it for a few minutes and then powered it down. About ten minutes later, it came on to the menu, froze and started doing the light thing again!!
Is there anything else I can try before I give up and buy a new one?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Ropiak86, this is very common for the first couple of attempts. The problem is that we all seem to under treat the heat part. I would suggest you try it again, step by step, but use the heat a bit more aggressive, just not careless.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Thank you for your comment. The guide suggested 25 seconds on each of the 4 sections. Would you recommend more time on low setting for each section? Say a full minute? Thanks!
さんによる
Don't focus to much on the time. Use a slight sweeping motion to ensure that the balls reflow nicely. remember, that the solder should not melt, just liquify enough to reflow.
さんによる
I ran the ps3 for about 20 minutes without issue and a restart. I'm going to cross my fingers that it's still working. Thanks for advising I go back in and redo it. I wouldn't have bothered otherwise!
さんによる
Good job getting it done. It does take a bit of practice and a lot of luck. sometimes it last for a good while and other times it gives out quickly. Consider having a professional reball done for a much more permanent fix. Your console is definitely worth it. Again, great job....:-)
さんによる
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 636
