Can I use a 2.16GHz 256MB logic board on a MacBook Pro 15" Core 2 Duo?
I have a busted 2.16HGz 128MB logic board, and have found a 2.16HGz 256MB logic board, can i use that as a replacement? will the extra 128MB be a plus or a problem?
tnx
"The 128 MB vs the 256MB is a function of RAM installed, not the mother board. Your machine should be able to take up to 2 GB of RAM:"
mayer, I believe he is referring to 128MB vs 256MB of VRAM. Quite commonly the base model 15" has half the VRAM of the upgraded models.
このアンサーは役に立ちましたか?
You are correct, my mind was elsewhere. Answer has been edited.
It won't necessarily fit, for instance a 2.4GHz Penryn board doesn't fit in a 2.4GHz Santa Rosa (one generation before) computer. Best to stick with the correct generation or else you tend to have problems with temp sensors and whatnot. Although, a Core Duo really isn't worth the repair.
このアンサーは役に立ちましたか?
This is most likely your current logic board a 2.16 Core 2 Duo: MacBook Pro 15" (Model A1211) 2.16 GHz Logic Board
The 2.16 board you found may or may not be a core 2 duo. It could be a core duo and unsuitable for you.
This logic board, a 2.33 Core 2 Duo will drop right in with no problems: MacBook Pro 15" (Model A1211) 2.33 GHz Logic Board
Although iFixit currently has it listed as "out of stock", I would contact them here and ask for one as they may have it but not gotten it to the inventory list yet: http://www.ifixit.com/Info/contact
To be sure all this is correct, please remove the battery and look in the compartment and its side walls for your exact model.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 1,810
