My charging port is damaged, can I replace it?
Can the charging port on a PS Vita be replaced without changing the entire motherboard?
Jerry, only if you find a proper replacement. you can de-solder the old one and resolder a new one. Problem will be to find a replacement.
このアンサーは役に立ちましたか?
amazon is selling charging ports
If I got a replacement dock do you know where I could find a guide to take me through it step by step?
I have a small amount of experience soldering but I don’t want to go into it without knowing exactly what to do, I can’t find a guide anywhere on the net.
YES you can, I did i brought a vita charging dock and brang that to ubreakitifixit .... they soldered that new piece on .... the new piece coming from the dock has a board attached to the pins and bascially there is NO LOOSE PINS THAT GET SCREWED UP OR DAMAGED ....
このアンサーは役に立ちましたか?
btw the dock cost me 10 bucks and the soldering cost 80 .... the ps vita phat is worth that price in repairs in my books because of the extreme mods you can do to it :)
Where were you able to buy the charging port from please email me never stop striving a gmail.com
please tell us where you got the replacement port from
i can't find it anywhere
http://us.playstation.com/psvita/accesso... use that ... thats what i had the guy do ... but it eventually burned out ... maybe my soldering guy sucked or its not worth it ... maybe youll be luckier than I
i have it to you have to charge it with coumputer usb but you cant charge it while its on turn it off first but if didnt charge get the the charger up and down move it let the charger dance untile it charge it will work try it
このアンサーは役に立ちましたか?
このアンサーは役に立ちましたか?
Have anyone tried to fix it..do let me know how you did that..I stuck with my dead Vita...
過去 24時間: 5
過去 7 日: 16
過去 30 日: 61
今までの合計 28,267
6 件のコメント
THIS SUCKS!i i love my vita and for this to be a problem it sucks because it cost more to fix it then to buy a new one. or almost .
robin さんによる
Hi Guys,
me son facing the same problem his Vita don't charge unless he push the connection
up or down a little which makes it hard to hold it all the time specially when playing
while charging
we rang Sony regarding the problem and their answer was wear and tear and a replacement will cost $180 !! even tho the vita still under 12 months warranty
how can I pay this much to fix input when the whole thing brand new cost under
$250 !! I'm going to think twice before approaching Sony products in the future
anyway
the question is how to fix this charging issue? its not fully damaged as it does charge
when lifting the connection a little .. can you please show us step by step how it
can be opened and checked internally for damage or maybe a loose wire?
thank you in advance
and thank you NOT Sony for letting our kids down.
cheers
alaz3r
alaz3r さんによる
I have a similar problem my vita hasn't wokred for a year now because of the port.when I plug in the charger I am lucky if the orange light blinks twice. So can any one help me plze because I tried doin every thing I just want to play my vita and enjoy it if any one can help me and answer back May god bless you.
jeaden Owusu さんによる
Same here, orange blink twice
nanihothearts5 さんによる
Hi yes I want to know is their any other kind of charger that I can use to charger my ps vita because I dont want to mess it up it old and
ltanyahoyles36 さんによる
1以上のコメントを表示
