メインコンテンツにスキップ
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
Is there a way to tighten-up/more resistance the analog sticks?
I am trying to find a way to tighten-up or give more resistance to the analog sticks of the controller. In two areas, first in the amount of pressure that it takes when pushing it down .... i would like to make it stiffer/harder. Second, in the left to right movement in the analog stick, in order to reduce the sensitivity during game-play.
As it stands right now i just barely tap the stick, left or right and it travels way past the intended target, forcing another tap the other way to correct it ........... ant ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
maxx, I just took a look at the analog controller and I do not see anything that would allow any adjustment. I would suggest to replace the stick with a set of new ones. They are relatively inexpensive and it only requires basic soldering skills to replace them. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
maxx さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 39
今までの合計 9,178
