Squealing when it is turned on.
Model # 11097892601 With the model number can you tell us where we need to find the roller to replace?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds to me like the belt.
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
http://www.repairclinic.com/Kenmore-Drye...
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
==OOPS==
Sorry mayer for messing with your answer. Just wanted to place the page from the manual to help out.
oldturkey03
このアンサーは役に立ちましたか?
While you are in there, replace the roller wheels AND the belt. you'll be glad you did later on.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 25
過去 30 日: 140
今までの合計 30,700
1件のコメント
your dryer should also have the repair information that you are seeking in the tech sheet that is normally behind the bottom front service panel of the dryer.
oldturkey03 さんによる
