メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
button touch buttons not working
I got my phone wet. Not hing worked. So I pulled it apart and cleaned it all up because it had salt stains. Now everything works except for my buttons down the bottom on my Samsung galaxy s3. Is there anything I can do to fix it so they work again
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
I will stress that if your phone was submerged in salt water make double certain that you do an exceptional job cleaning everything or the phone wont last long at all, here is the part you need, https://www.gounlock.com/details.php?ite..., but it could also be where this part plugs into your motherboard if it's corroded so I would double check and do a good cleaning with alcohol and a toothbrush, use these cleaning methods they are for an Iphone but it shows how to stop corrosion, iPhoneの水濡れ・水没ダメージからの復旧方法, here is a teardown guide also for your Gallaxy, good luck. Samsung Galaxy S III Teardown
iPhoneの画像
ガイド
難易度:
難しい
1 - 2 hours
Samsung Galaxy S IIIの画像
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
This could be a Hardware issue. However, let do a quick reset and see how this works out:
Go to Settings
Select Apps
Select All (Look for ALL on top menu or swipe to the right to get to ALL)
Select Google Services Framework and tap Clear Data.
Turn off (shut down) your device and turn it back on.
Test the phone to see if it will black out again.
Hardware issue:get new here
Does the phone have any physical damages?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Here Is The Solution Samsung Galaxy S3 Touch Keys Not Working 100% Tested Solution
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
he everyone ijus wanna say tht my Samsung galaxy s3 back button and main button and option stooped working and I believe tht I was using my ponw when it was raining and if anyone see this plzz reply and say if it is rain or other problems and thku and have a saf eday
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
mean"i jus wanna" nd "I was using my phone when it was ....."
さんによる
コメントを追加
回答を追加する
Adrian さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 6
今までの合計 30,442
