The radio is reading code 1
i took the battery offf to replace it and now the radio wont work it reads code 1? what do i do
この質問は役に立ちましたか?
この質問は役に立ちましたか?
pat joy, you need to reset your radio code. You could give this a try:
Call your Honda dealer and give them those numbers. Or just follow the directions on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 10,617
1件のコメント
You'll need an unlock code, which you can get here: https://radiocodevault.com/honda
James さんによる
