メインコンテンツにスキップ
PS3スリムは、オリジナルの型番CECH-2000を持つPS3ビデオゲーム機のセカンドバージョンである。ソニー・コンピュータエンタテインメントによって製造され、初代プレイステーション3の多くの問題を修正した。2009年9月1日に発売された。
The lid will not come off
i have tried everything to get the lid off the playstation 3 slim and will not come off at all. what should i do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
最も参考になった回答
I don't know why no one will answer this question clearly, this is the third forum I've seen without it. There is a HIDDEN screw, even sneakier than the ones under the black square pieces - it's underneath a BLACK STICKER WITH TEXT ON IT, right on the bottom of the PS3, hiding in plain sight. You have to PEEL OFF THE BLACK STICKER to reveal another of those black plastic squares, which after removed will reveal the final screw. (caps for clarity)
このアンサーは役に立ちましたか?
スコア 7
8 件のコメント:
I've seen "remove the seal", but that doesn't convey what you're looking for. Again, on the bottom of the PS3 where all the other screws were, close to the center, there's a black sticker with text on it. You have to peel that sucker off, and voila. You're not crazy, I'd guess probably 82% of people fall for this like I did, because it's a total curveball. Like a trapdoor under a rug.
さんによる
@Chris B thanks man you are a life saver
さんによる
God Bless you Chris frustrated i was about to go hard way and most defiantly damage
さんによる
Thank you so much. I was about to break this $@$* even more, lol. You're the man! XO
さんによる
Saver
さんによる
3件以上のコメントを表示
コメントを追加
Make sure all screws are taken out. There is one that is under the seal. That one is usually the one that people forget to take out.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
i took out all the screws even the software but the lid would come off from the front where you insert the disc only the back of it would come off. any recommendations please?
さんによる
Same nothing worked
さんによる
コメントを追加
You prob missed a screw. Look at the guide on here and make sure you did it correctly.
Or just jerk it real hard. It'll come off
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i did that i have used a tool to ply the front top lid off of the PlayStation and it will not come off at all
any idea what i can still do?
さんによる
コメントを追加
I hade the same problem There's one more hidden screw found out the hard way
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
marioehusari さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 51
今までの合計 8,147
