The left side of touchscreen does not respond, right side workd fine.
is there anything that can be done to repair this gps unit?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
daniel garcia, replace the digitizer or the total display assembly. you can check check on here for a new part and follow this guide up to step 4 for instructions. Remove the ribbon cable and remove the LCD and digitizer from the front bezel. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 4
今までの合計 789
