Starts only with command key pressed down.
My laptop does only starts when the command key is pressed for about fifthteen sec. when starting the machine.
There is a discussion about this problem:
http://discussions.info.apple.com/thread...
I tried everything that seems possible, incl. all the tips discussed in the Link (above). BUt still.
When i press the command key while starting the machine everything is fine, but if not, the machine goes out, as described in above discussion.
Thank you for any suggestion that could help me solving this problem
この質問は役に立ちましたか?
