What fuse does my tv take and where can I get one
fuse is blown in the back of tv, sanyo dp19649 lcd tv...i need to know the replacement fuse number and if i can get one at radioshack or another similiar store.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Take a look at the back of your TV there should be a chassis number. If you post the chassis number, it will make it easier to find the exact specs for your TV. It should be a 4 amp fuse and they are run of the mill and available at Radio shack. But, there is probably a reason why it blew... attached image shows the location of the fuse on your power board. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 4,187
