メインコンテンツにスキップ
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
798回答 すべてを表示
Snapping iPod together causes battery to drain?
I swapped my HDD for a 128gb mSATA SSD using a ZIF adapter. Everything was working (iTunes detected and restored the iPod successfully, it even showed the 120gb capacity) until I snapped the panels back together, then the iPod started getting hot and the battery drained very quickly. I separated the two halves again, and again it started working. I'm not sure what's going on.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I would make sure that you have enough clearance between the battery and the back cover. It sounds like it is shortening out due to not enough clearance.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I had considered that, but the battery works fine now that I've replaced the old hard drive and reassembled everything. I even made sure that the SSD was not making contact with either the back panel or the battery's ribbon cable.
さんによる
I think I'm going to swap out my slim back for a fat back. Will my headphone jack assembly still work in the fat back?
さんによる
Yes it will, just check the length and make sure it reaches without difficulty. The thicker back usually has a longer cable for the jack and the hold switch, but in your case it may not make to much difference, since you are not using a thicker hard drive. Hope this helps.
さんによる
I appreciate the feedback. The current set of ribbon cables has a lot of give (much more than the .12" difference in thickness between the two models), so I'm feeling confident that the fat back won't be a problem.
さんによる
コメントを追加
回答を追加する
zachstephenszach さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 518
