メインコンテンツにスキップ
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
106回答 すべてを表示
締切られた回答
heat sensor wire disconnected
Trying to install new hard drive I disconnected, unknowingly, the heat sensor wire from the board at the front of the computer. I tried tape. A tech tried soldering it into place but missed. Fan runs all the time. Can I just get the board that the wire connects with?
Or does anyone have a better suggestion?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Charles Nix, so how did you end up fixing it?
さんによる
コメントを追加
2件の回答
ベストアンサー
I didn't fix it. The fan just runs all the time. What I have discovered through this and other repair attempts is that "cables" in the mac mini are horribly fragile and reattaching them is almost impossible--particularly reattaching cables from fan, ir, and something else (?) to the interconnect board. Tbe Ifixit is a great site. There is a great guide to tearing down the macmini, but it failed to caution about removing interconnect cables. It apparently is very easy to dislodge the sockets the wires fit into. I don't know this but I do know that I couldn't reattach cables and could"t find a guide to reattach the cables.
Charles Nix
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
you could jump the connections, but you run the risk of the computer overheating. You could look for a fan control application.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 1,329
