メインコンテンツにスキップ
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
798回答 すべてを表示
締切られた回答
Broken headphone jack, tried to replace, but...
Ive got a new hold switch/headphone jack for my iPod. However when I went to install it I realised I have lost/broken off the little brown clip that holds the connector in place on the logic board (http://s1.guide-images.ifixit.com/igi/6G...). There is no way it will hold without the clip. Is there anything I can do, or am I able to purchase another clip?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Unfortunately, I'm aware of anywhere that sells just the clip.
Some have had nominal success with electrical tape holding down the cable, but this is temporary and not very likely to work.
Your best bet is most likely to purchase a dead logic board off of eBay and carefully scavenge the clip.
Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
that happen to me with an iphone and I just had to use an electric style putty/rubber cement to fix it. I tried the electric putty on one item and haven't had a problem. However I quickly relies that with the putty it would make it difficult to re-repair if needed so i went with the rubber cement and it works great on my iPod for this purpose.
Hope this helps Ciao,
Maverick6017
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,943
