メインコンテンツにスキップ
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
24回答 すべてを表示
締切られた回答
No display,system seems hang after power ON.
No display getting in both internal and external display device,after powering on.keyboard also not functioning
(tried external keyboard),only two led(Lamp,WIFI)see glowing,cpu&Cooling fan are seems in working condition.pls help to resolve this issue
regards,
ranjith
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Just had the same problem as described above. Retraced my steps (after cleaning insides) and noticed the RAM module wasn't fitted correctly (it should be springy when released from the latches and "jump" out). Made sure it was fitted properly and now all is fine again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It's hard to diagnose this issue without being in front of the system, but, here we go:
If you are not getting video on an external monitor as well the motherboard has failed. More specifically the graphics on the motherboard has malfunctioned. The whole motherboard would need to be replaced for this system to work again. It may be more cost effective to replace the system. You should still be able to pull the hard drive from the system and get data off of it.
The motherboard will probably cost about $125 if you choose to replace it. Sorry to head about your issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 1,962
