メインコンテンツにスキップ
4インチディスプレイ/カラーバリエーションは様々あり/3種のモデル/16, 32もしくは64 GB容量
331回答 すべてを表示
締切られた回答
How to fix a dent on the top right backplate corner
My ipod fell on the top right backplate corner and there's a dent n the the top button doesn't work is there a way I can undent it and fix the button at a cheap price also the camara is on the bottom of the dent
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
If you use needle nose pliers, put a little kapton tape (or electrical tape) between the pliers and the rim to prevent scratching from the pliers. ;)
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I guess that that would be a very difficult repair. You'd have to completely dissemble the iPod until you only have the case left. You might look at the teardown to look when they got to the case. Which if, if I'm not wrong at the end. I don't have experience with outdenting aluminum things. I think it's possible but it won't look pretty anymore. My advice is searching for a replacement back, or as I do with my MBP, just live with it as long as it doesn't hurt the functioning of the device. I'm sorry for you that you broke your device that fast. There is quite a lot of adhesive that you will have to face until you get to the case. I think that putting all that adhesive back would be quite difficult. The actual outdenting would also be quite the challenge according to me. This image is from the teardown and shows only the backplate for reference.
To answer your questions about the buttons: I've searched a bit on iFixit and I don't see any available parts yet, you'll have to wait until that is added. Yet if you really (and I mean REALLY) want it fixed, the best solution would be to buy a new one, sorry.
Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I would recommend a screen removal and a thin pointed needle nose pliers. Try and get just the rim of the metal backing where the bend/dent is located and pry the screen back so the button can retract and work again. I would order a back replacement ASAP and find out which replacement cables are needed and wait for a good collection of instructions and do some soldering.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 4
今までの合計 3,487
