メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
904回答 すべてを表示
締切られた回答
850 mAh battery for an 7G iPod Classic?
Hi, I have a 7th Gen iPod Classic, and I want to change the battery in it. So I wonder if it would be possible to put a thick 850 mAh battery in it, by changing the rear panel of my iPod into a bigger one ? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Yes it is possible, BUT that will extend the clearance between the case and the hard drive. This could lead to a loose hard drive and may damage the drive, the cables, or the connector.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I want to put a 240gb HDD in it, so that's not a problem. If I keep the 160gb HDD, can I put some paper or something in it to avoid the clearance ? And will I have to take a Ipod Video or thick 6th Gen Ipod Classic rear panel ?
さんによる
The iPod video will not fit your front, so you'll have to go with the 6th gen. Try to use some packing foam to fill the space.
さんによる
Hi. I have an issue : the battery seems not to charge (actually, the battery logo is full in a few seconds while I hadn't yet charge the battery, and it drains in a few seconds too.) So what am I supposed to do ? Thanks
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,979
