メインコンテンツにスキップ
Guides and repair information for the second-generation of the North American Honda Odyssey, produced between 1999 and 2004.
43回答 すべてを表示
brake light is out
i have replaced the brake light but it still does not work
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
When you say you replaced the brake light, what exactly did you replace? The light, the bulbs?
さんによる
コメントを追加
4件の回答
最も参考になった回答
Anne, check fuse number 47 in the Under-the -hood fuse/relay box for continuity as well as fuse number 9 in the under-dash fuse box. Check your light bulbs, they are dual-filament bulbs (type 7443) 21/5W and are on top of the tailights. Check the Brake Pedal Position Switch, use a multimeter or continuity tester to make sure it is working. If all that is okay, and since both sides are affected, there is a possibility that your Brake Lights failure sensor needs replacement. It should be located at the left rear of the cargo area. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
There is no fuse # 47 for 1999 Odyssey. Is there a different number for that year?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The under hood fuse is called STOP on the fuse box cover and in the owner manual. This is the one controls the brake lights and brake switch. (This fuse in All Hondas should be in the under hood fuse box but with different number.)
さんによる
コメントを追加
My brake lamp came on my 2000 Honda Odyssey does this mean a bulb is bad? I thought I had a brake problem? Thanks for your help??
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I have Odessey 2004 and dashboard shows indicaror for "Brake Lamp". Any idea whats the problem?
さんによる
Mine too. Any solutions?
さんによる
The under hood fuse is called STOP on the fuse box cover and in the owner manual. This is the one control the brake lights and brake switch. (This fuse in All Hondas should be in the under hood fuse box but with different number.)
さんによる
コメントを追加
Would a bad brake light sensor cause the STOP fuse to blow? I found that my key interlock switch not working and found this fuse blown, replaced it with another one it blew again the moment I step on the brake.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anne さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 34
今までの合計 17,083
