メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
Middle frame insulating adhesive film: necessary?
I'm about to replace a middle frame of an iPhone 4S.
The one I ordered came without the adhesive film that should prevent contact with the LCD
Do I really need that? What is it for? Can I put another kind of sticker or simply nothing?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi,
I dont know how important is but i found this info about heat shield:
"There is disclosed a liquid crystal display (LCD) device that prevents degeneration of a displaying performance due to heat generated in the LCD. A heat shielding thin film of an aluminum-contained material, which is disposed in a receiving container, shields the heat additionally generated during a converting process of power for driving a lamp in an inverter module, thereby minimizing the heat to be transferred to a reflector panel. Therefore, the heat generated during a process of producing light is efficiently blocked and discharged, thereby minimizing the degeneration of displaying characteristic"
I have changed many middle frames for iphone 4 and there was not any problems.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Jacopo Scarpellini さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 848
