Why wont the computer read my iPod nano?
every time when i connect the usb cable to the computer it wont read my iPod. i cant insert music nor take out music.
The order of pluggig the iPod in should have no effect. Have you tried using another USB port if available and/or onother cable? Do you use 3rd party cable?
このアンサーは役に立ちましたか?
Does the iPod show that it is charging when you plug it in? I would suggest verifying the dock connector on the iPod is intact (i.e. not broken, bent, etc.), if the iPod doesn't show any indication that the iPod is charging. Otherwise, Timpetou's answer is also what I would try.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 717
1件のコメント
Are you bringing up iTunes after you attach the iPod or is it comming up on it's own after you attach the iPod?
Ken さんによる
