メインコンテンツにスキップ
GoProやセキュリティカメラを含むカムコーダー、その他ビデオカメラ用修理ガイドならびに製品サポート
406回答 すべてを表示
How to use JVC Everio GZ-HD6 as a backup disk for computer?
I have a JVC Everio GZ-HD 6 and want to use its 120GB built-in hard drive to back up my iTunes Library folder. But I also want to continue to use the camcorder unaffected. The hard drive is read-only and is MS-DOS formatted.
How do I make the drive writable, and use it as a drive, whilst still being able to use the camera for it's intended purpose?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Great Question +
さんによる
I agree, this is a very useful question- however, as more and more camcorders nowadays use SD cards, this specifically becomes irrelevant. But it's nice to have a camcorder with a second use. No need to carry around a camcorder and external HD when traveling.
さんによる
コメントを追加
2件の回答
ベストアンサー
This may work:
1) Clone the drive to back it up
2) format
3) partition
Hopefully this will work for you. I'm assuming you know how to do all of these steps.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thanks very much! Can you do all these steps in Disk Utility? If so, yes I can
さんによる
Cloning I guess you can but most people like super duper (and carbon copy cloner is good i hear). Most disk repair softwares have such functionality. Formatting and partitioning can easily be done in DU.
さんによる
Thanks!
さんによる
コメントを追加
You would have to format the drive from your mac with a partition. But I don't know for sure that the camcorder would work without it having to format the drive again and possibly removing the partition.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yeah, I can pretty much do nothing to the drive in it's current read-only state. I'm worried about formatting it because it's OS might be stored on the hard drive
さんによる
コメントを追加
回答を追加する
QEII Student IT さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,519
