メインコンテンツにスキップ
HPと合併以前のCompaq社は様々なモデルのラップトップコンピューターを製造していました。現在では、大部分のベーシックな特長は残したままで、HPによって製造されています。
295回答 すべてを表示
My compaq presario f700 has a blank screen, power working
I have tried hard reset, my ram is sufficient and i think there is some problem with the graphic card nvidia chip.
i have read many forums and found out it has to be reflowed or solder needs to be fixed.
any details of its repair?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
muzammil , the first thing I suggest you try is to attach an external monitor to it. If that works, you will at least know that it is not a reflow situation. Then the problem is with either your inverter, your LCD or your cables. If it does not work, you could consider a reflow. Problem with that, it is not as easy as it might sound. If you never have done one before, I would definitely take the time and work on some old boards first. Make sure that you have the right tools (sorry, hair dryer's are not the right tool) You need to be able to control temperature for a set amount of time etc. Take a look at this this video for the professional approach and this one for a more home made approach. I recommend you look through this note. It does explain it pretty good. This is not to say that an oven or a hot air gun will not work, but it will not be as accurate and thus has a higher degree of failure. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
thanks for the advise... i got it repaired from professional and planning to change my laptop soon.. :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
it is working ok but when i stop and tray again to start it is not starting
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
muzammil さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,046
