メインコンテンツにスキップ
Nintendo DSiは任天堂 DSラインの第3番目となるモデルです。2008年後期に日本で発売されました。
Why won't my DSi turn on?
My DSi was working just fine and I was playing my Pokemon White Version 2 game in Pokestar Studios when I closed my DSi and it turned off! I pressed the power button and held the power button, but it wouldn't turn on. After a while, it turned on but it went to a black screen without a yellow light. Now what?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 37
10 件のコメント
thanks its working(posting on dsi)
from God
さんによる
mine is charging, and the same thing is happening, I was making a Flipnote, and it turned off.
さんによる
I was playing Mario party on my dsi then it just turned off, I pluged it in the charger, same thing! I tried opening it againand it did not work. <:(
さんによる
Mine says an error has occurred when it turns on.
さんによる
My sister was playing her dsi and then she turned it off because she didn't want to play anymore. She opened it and turned it on but it would turn on for only a second and then turn off. She tried charging and left it charging for a day to see if it would work. Next day, it still does the same thing. Im really confused it was working?
さんによる
5件以上のコメントを表示
コメントを追加
13件の回答
最も参考になった回答
Hi, take the battery out for about 5 mins. Put it back and plug the charger in. After about 1 hour of charging see if it turns back on. Write back on what u did. Good luck.
このアンサーは役に立ちましたか?
スコア 5
5 件のコメント:
I did that and now it wont sit there and charge i have to hold it to make it charge and sometime it doesn't even do that
さんによる
did not work :(
さんによる
nope.... did NOT work....
さんによる
It doesn't seem to be charging, when I took the battery I checked it to see it it became round or inflated, it seemed fine and stuff, and it looks like it took charge. I don't think I can swap the battery yet. When I plug it, the lights showing it's charging - oh yeah I'm stupid.
I did notice it uncharging quickly, so yeah. It's the battery, and no one has a dsi anymore. Fiddlesticks
さんによる
Hi, I don't have a battery for it, so I can't put it back in. I have one, but I lost it.
さんによる
コメントを追加
Alright! Thank you so much benjamin! It worked! Now i can play pokemon!
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
what did you do to have it work
さんによる
コメントを追加
I have had a bunch of DSi, DSiXL and 3DS come in lately with completely dead batteries meaning they just failed. After switching out the battery then the unit fires right up. Try pulling the battery for 5 mins and then charging but if that doesn't work then try swapping out the battery for a new one or borrow one from a friends DSi.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
hello, I tried swapping the battery with a friend's. But my DSi won't turn on, but does charge. Checked the battery points, but they were okay. Any idea what it could be?
さんによる
コメントを追加
If the bottom LCD flashes (or top) and your power light does and then it shuts off, it might the be ribbon cable. If it's damaged, then you will have to buy a new LCD, as the cable is attached to the screen. They go around 10-20 dollars on eBay.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Do any know how to fix DSI: like when i turn it on the top screen turns BLACK, and bottom turns WHITE what should i do??
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
resit ribbon cables and if not replace both screens will cost u about £5 by a water damaged dsi nearly almost guarantee the screen will be ok on water damaged console so use it for parts youtube have tutorials its so easy :) good look
さんによる
コメントを追加
Hello there. My Nintendo DSi has not been turning on for the past five years (July 2010) and I need some advice in order to turn it back on. My laundry had been placed into a washing machine with the DSi in my pants pocket. When I took the DSi out of the machine I tried drying it in white rice. After a few days of drying, I press the power button but nothing but a flicker of the red power light. No matter how much I charge the handheld, it still won't budge turning on.
Nowadays, I still struggle to to turn on my DSi but has different affects of turning on. Instead of the red flicking power light, the blue power light comes on with the a white screen (mostly). Sometimes my DSi goes to the home menu but will not run any applications, probably due to water damage. It always brings up a black screen with a message on the bottom screen, stating that an error occurred and that I needed to refer to the manual.
If any of you guys know what is wrong with my DSi and knows how to fix it, tell me. I cannot seem to find any more active repair shops so please help.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi can someone help me my younger brother was playing my white Nintendo dsi yesterday and when I wanted to play it it turned on but it kept turning of please help me?!
さんによる
dearbh, I think you just need to charge it. If I'm wrong, that's because you didn't specify enough.
OP, your NAND probably got busted.
さんによる
コメントを追加
Sorry, still no. I've tried quite a bit and have been aiming at avoiding taking it in to get checked. The operations carried forth on my DSi could cost quite a fortune. Sorry Benjamin and everyone else.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I've had a dsi for a few years now and when I turn it on, the. Lie light comes on but it's just a white and black screen and on the top there is something weird written down but the orange light comes on however the green light will not come on but if it does, I try clicking on something and a message comes up tell me to go to the manual. HELP PLEASE. I really need my DSI to work because I've got very important photos on there please help me
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Me too, not the problem, it won't turn on, even when charging, I lost the battery and I also have REALLY important things on there. Please help me.
さんによる
Get a new batt Ocean Blaze.
OP, your DSi is bricked. Get a new one. That text on the top screen is an error code.
さんによる
コメントを追加
when this happened to me I eventually got it to work by shaking it. This was about 3-5 years ago though. Yours is older so it might not work.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
hi my DSI wont turn on i have had it for 2 years and lost it for a wial and found it mine turned on for a spit second and wont turn back on i have chared it for 5 hours strait and did what you said it wont turn on at all
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
You need a new battery. Your current one has died.
さんによる
Is there any way to keep my pictures while changing my battery? That's the main reason I even want to turn it on.
さんによる
コメントを追加
Hello everyone! today i just want to say that what you people are posting about the DSi problem's, right? Well i got a solution to those problem's. Anyway's the solution to all of those problem's is to go into the Nintendo shop and tell the staff to fix your DSi. If that doesn't work then search on YouTube. If THAT doesn't work ... then ... probably go into the DSi and try to fix the DSi yourself. If THAT doesn't work then i don't know what else you can do...
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
hello everybody
today this morning i was playing pokemon black then i putted to charge later afternoon i played pokemon platinum then i turned it off and putted on charge an hour later i wanted to play platinum so i can raise my gabite my dsi turned on but both screen were white i tried pressing the start botton but it wont even turn off really wierd first happened to it so please help
thanks
さんによる
I think your DSi nand got busted somehow.
Also OP, that's not a fix.
さんによる
コメントを追加
Put it on the charger and if that doesn't work take the battery out and hold the power button and then put the battery back in and hold the power botton down and it will come back on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I recently picked up a dsi XL with the same fault, found out it's the WiFi module that's came loose, I popped it back in and it was working fine.
To get to it you just need to remove the battery cover, battery and bottom shell, it's an easy fix
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
omg mine did the same
さんによる
コメントを追加
回答を追加する
Benjamin さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 27
過去 30 日: 118
今までの合計 42,775
