メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
iPhone 3GS storage is full
I can't download any more songs on itunes or take a picture/video as the storage is full. How do I get vsome of the storage back?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Remove apps you don't use.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
My iPhone is a 6 or 7+ but the storage is 32GB and can’t free up storage we tryed iCloud still not please help
さんによる
コメントを追加
I can understand you very well.Because this situation drives people insane indeed. I once have the same trouble.here's some tricks to free up space on your phone.
1. Go to Settings > Safari > Clear History & Clear Cookies & Data. This takes up a surprising amount of space if it isn't cleared on occasion.
2. Go to Settings > General > Usage > Here, you'll see a list of apps that are using your space sorted from the app taking the most space down to the app taking up the least space. Right from here you can remove apps that are killing your storage.
3. I would recommend backing up photos and videos to your computer regularly than deleting them from your phone. Plus you can limit music to what you actually listen to regularly.
4. You can also try some softwares .iMyfone Space Saver for iOS is efficient. iMyfone Space Saver for iOS can free up iPhone space and speed up your device by two steps. This software can deeply scan your iPhone can find the junk files which need to be deleted. Also it make lossless photo compression to save your space. You don’t even have to worry about your photos will be ruined because the compression is lossless and your original photos will be backed up automatically to your computer!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Paul Carruthers さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 471
