What other years is my 1997 LE camry engine compatible with?
which models are compatible? and also years? for 2.3 and or 3.0 liter.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
nick the 3.0 L is the 1MZ-FE
Applications:
1994–2003 Toyota Camry (V6)
1994–2003 Lexus ES 300 & Toyota Windom (Japanese domestic market)
1995–2004 Toyota Avalon & 2000 Toyota Pronard (Avalon for Japanese domestic market)
1997–2003 Lexus RX 300
Toyota Harrier (non-US markets)
1998–2000 Toyota Sienna
1999–2003 Toyota Solara (V6)
2000– Toyota Estima (Japanese domestic market)
The 2.2L is the 5S-FE :
Applications:
ST204 (US Generation 6 Celica GT)
ST184 (US Generation 5 Celica GT, GT-S and SX. Australian Generation 5 Celica SX)
SW21 (US Generation 2 MR2 N/A)
SXV10 (Camry 1992–96)
SXV20 (Camry 1997–01)
More on this information on here. Hope this helps, good luck.
このアンサーは役に立ちましたか?
I wanna swap a 3.0 from a 1997 camry and put it in 2000 avalon 3.0 but there are more electronics on my avalon than on my camry do they sell a hornest to make the camry motor compatible with the avalon
Would a 2000 Camry 4 cilynder fit a 96 camry
Would a 2000 Camry CSI Engine fit a 1995 Camry CSI Body? I want to drop a new motor in my current 1995 camry as the body is immaculate and i have found a willing organ doner
I have a 1994 Toyota Camry and a 1996 Toyota Camry both have the strongest engines I've ever heard or ran and the AC is ice cold on both the bodies are starting to fall apart but I would like to put one or both of the motors into a Toyota minivan the newest possible what minivans made by Toyota are compatible with these motors I believe one is the V6 and the other 2.2L?
I have an 02 Camry and don't know if a 01 Camry engine is compatible to swap
I have a '02 XLE 4cyl. And 98 LE
interchange wise the old 14" wheels do NOT work on the newer model- interference with calipers. I'd like to know what will fit from 02 to the 98. Seats ? Engine ? Rear view mirror with compass - Did transplant. Can't imagine any body interchanges. LOVE THE TACH in the 02 XLE. The lighted dial follows the needle thru the revs. UNIQUE
このアンサーは役に立ちましたか?
As far as one touch power windows. I Couldn't even transplant to a 06LE. MIss the little things of the XLE
I have toyota camry1992 2.2 vin 4T1SK12E9NU072327 can I swap the engine with older toyota camry 2.0 from1989?
Can this alternator from this engine number fit into a 2003 Toyota Highlander? What vehicles can if this can't?
このアンサーは役に立ちましたか?
Queen MFB probably not because of the alternator bracket most likely being different. What engine size is your Highlander?
過去 24時間: 2
過去 7 日: 11
過去 30 日: 112
今までの合計 38,669
10 件のコメント
Are you trying to find an engine? Or you not sure if yours is a 2.3(? I believe that model year only came in a 2.2L not a 2.3L) or 3.0 liter. As you know one is a 4cyl and the other a 6cyl. So exactly what are you trying to accomplish?
oldturkey03 さんによる
I'm looking for any body to fit my 2.2L 4cyl 1997 Toyota camry le engine. Motor is awesome but body literally falling apart HELP please.
Tammy さんによる
can swap computer of camry 1997 with 1998
Foi さんによる
Which Engine can I swap with my 2.0L Daewoo Leganza CDX 2001
Benard さんによる
I have a Toyota harrier 5S-Fe 1998 model. The gearbox has broken down. Can I replace this gearbox with one from a 1mz engine
Obed kunda さんによる
5件以上のコメントを表示
