Keeps Circling In Same Area
Keeps circling same area over and over and then stops. Battery is still charged. How do I correct this problem? Thanks.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Diane, this can be caused by dirty or defective bumper sensor as well as dirty cliff sensors. Clean the Roomba with compressed air and "slap" the front bumper. Apparently, the front bumper mechanism can get stuck with any contact with a wall etc. which will make the Roomba back up. Use these guides to work on your Roomba. Check on here for more information as well. Hope this helps, good luck.
このアンサーは役に立ちましたか?
Did the trick thank you!
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 10,527
