メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
continually searching with/without sim
Changed a kit on an iphone 4 three months ago...been fine....now all of a sudden it just says searching for a signal...doesnt recognise me taking sim out or putting it in...
Must be somebody clever out there who has the answer :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 16
2 件のコメント
Are you running ios 6?
さんによる
Go to settings, tap cellular and on the cellular data, enable 3g and the data roaming after that remove the sim card and put it back.
さんによる
コメントを追加
15件の回答
ベストアンサー
this is a date/time error. Join your WLan with the iPhone or manually set the date/time. Remove the sim card and put it back into the phone. Now you can enter the sim-code.
このアンサーは役に立ちましたか?
スコア 20
22 件のコメント:
You're the best. I tried 3 hours to fix it. Tried everything, hardware , coils everything...and your solution fix it...incredibile. Thank you!!!!!
さんによる
you're the best man, i almost killed my iphone 4s today and thank God i found your post in time... it was just the date and time and now it's working...
さんによる
I had same problem. I thought it was hardware and trying for days. I fixed the date and it is fixed. So simple and yet so difficult to find the solution. Brilliant solution from ifixit. thanx
さんによる
thanq thanqqq dear u r the best.........
さんによる
Awesome! thanks much for the solution
さんによる
17件以上のコメントを表示
コメントを追加
Put another persons SIM card in your slot, wait 2-3 minutes, have someone dial the phone number of the SIM card you placed in your phone, pick up when it rings and let it sit idle for about a minute before hanging up...your phone should recognize that card and then you can remove it. Put your card back into the phone, if your phone doesn't recognize the card, your SIM card is damaged most likely, call your service provider, they can check it over the phone ;). Mine was a bad SIM card.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you so much. I was desperate and wanted to give my new iPhone to the service. Now it works!
さんによる
コメントを追加
i reset my iphone 5c with this same problem.. now i cant activate it.. its still always saying "searching..." any solutions?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
さんによる
Me also have the same problem...I can't activate my iphone 5c now...
さんによる
コメントを追加
my iphone says searching all time even without the sim card _ and if i lock it,its gonna come lot of languages changing on the screen..................plz help me if u know whats going on!!!!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My iPhone 7 is searching and imel number corrupt
さんによる
コメントを追加
Hi!
I just joined ifixit to say THANKS. This procedure solved my problem, THANK YOU AGAIN!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i raed Mark's answer which has worked for many, but those steps are not working for me, can someone please help, really desperate.
Cant understand why its not working for me. What is sim code is it same as sim pin, then i can't edit that
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My wife gave my daughter her iphone and suspected she broke it. Cellular dealers were saying it was a damaged sim reader. The iStore wanted money just to book a techician to look at it. Thanks.... This is a great post that saved me money and fustration!!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If this works i Will appreciate, but i have a problem....
I dont find the solution so, i restored my iPhone 5c by iTunes
Then, i can't register my iphone trought wifi way, and iTunes way too.
I was investigating and then i put the iPhone in recovery mode, and the process wont complete because an error from itunes. I stay here. If you help me i Will love you forever...
(Sorry For my english)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i cant active my iphone 4 ,same problem are any sorte out this
さんによる
コメントを追加
Hi.
I got the same problem. I done what is the first message sad but it dose not working for me. some reason . I got a ipone 4s.
I would be grateful if you could help me with it.
Thanks very much.
Krisz
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i try to change time/date and no affect
help me plz
it is seaching ONLY
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When time and date change toggle airplane mode for 10 seconds if that fails turn phone off and on
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Still searching !!!
さんによる
コメントを追加
This is not working for me. I using iPhone5s. Kindly help me pls. what is that sim code.My Date/time is correctly only. But still i have this problem. My phone is still searching with or without sim. Is it a hardware problem nor software? Kindly guide me
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
And i also tried my sim with other phone its working cool. And other sim is not working in my phone. So i guess sim is in good condition.
さんによる
Man your cellular IC is gone like mine...got it fixed today...they replaced the IC
さんによる
How much did it cost
さんによる
コメントを追加
Tried everything didn't work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
really very helpful you sve my lots of time and money also very thanks marks.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My ipad 3 is just showing searching with out sim in it, also have updated to the lastest Os but I could not install. Kindly help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
splodger さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 28
今までの合計 77,613
