メインコンテンツにスキップ
Wi-Fi版と3G版があり、16GB、32GB、64GBのストレージを搭載した第1世代Apple iPadの修理情報。2010年4月3日発売。モデル番号 A1219およびA1337。
266回答 すべてを表示
締切られた回答
Touchscreen response erratic after battery replacement.
I replaced the battery in my iPad. After reassembly the touch screen is very erratic. For example, in landscape mode, the Slide to Unlock does not respond. In portrait, it is very jumpy, mostly jumping back to the left. One time, buy moving very slowly, I was able to unlock it. Since then I haven't been able to unlock it. The single time I was unable to unlock it, it seemed fairly repeatable that near the bottom left (portrait) would respond. Only a small area on the top left would respond. The remainder of the panel provides no response.
Also, during removal of the screen, several of the metal clips broke off from the top.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Works now. I went back in and reset all connections. Now good...and breathing a sigh of relief.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 511
