メインコンテンツにスキップ
モデル番号はA1366/8もしくは16GB容量
175回答 すべてを表示
締切られた回答
The touch screen is unresponsive
i think the problem is sometimes it gets wet on my bag.. but its not too much..
i dont usually turn it off. i just used the sleep/wake button..
well, before, its touch screen becomes unresponsive already and all i have to do is press the sleep/wake button and suddenly its ok.. but the last time i put it out of my bag . the touch screen now is unresponsive ..
i have tried the reset.. and unluckily, refreshing on the itunes didnt work on my desktop, .. i tried to diagnose it and the error is 0xFFFFFFFF - i dont know what it means.. right now im trying the rice thing but its been a week.. it still stuck. :(
i hope.. repair would help.. or little cleaning ? does it need change parts?
Update
yes its ipod 6th gen.. hmmm i assume the water damage .. sometimes my tissue wipes spills on my bag.. although i have the ipod on a pouch..
regarding the diagnosis.. i just press the sleep/wake button, volume up and down together , i just read the instruction on some forums over the internet..
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Where does the error show up? How did you try to diagnose it? Do you have water damage or are you just assuming you do?
さんによる
コメントを追加
1 件の回答
ベストアンサー
You will have to repair the whole thing, not knowing without opening it up, and you would need to check resistances, voltages, etc. The easiest way is to find a repair place. Then get a warranty(will save you lots in the long run). And which ipod is it? If it is the nano 6th gen, go here: http://www.apple.com/support/ipod/servic...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 7,709
