メインコンテンツにスキップ
モデル番号A1285/8もしくは16GB容量
206回答 すべてを表示
Backlight not working, replaced LCD, still no joy
Hi guys
Have an iPod nano with faulty backlight, tried replacing the screen, still works (which is good because it means I didn't totally mess it up) but the backlight issue still isn't fixed.
Please if you could tell me what could possibly be wrong with it AND give me some tips on how it might be fixed?
Thank you
Ali
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
4件の回答
最も参考になった回答
This is normally due to the coil on the main board, not the LED.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Well, if you replaced the LCD to fix the backlight problem (and are sure the new screen didn't have the same problem), you will almost certainly have to replace the motherboard :S
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The backlight is not part of the screen. It is a tiny LED behind the screen and there are currently no vendors selling replacement LEDs on ebay. There are a few videos on Youtube showing the disassembly of the nano, and they can show you the location and how to remove the LED, but if you can't get a new one to replace it, why bother?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
desolder or replace the coil on the logicboard http://guide-images.ifixit.net/igi/UKWEb...
http://dl.dropbox.com/u/35194698/iPod/Lo...
order iPhone 3GS 6R8 COIL for LCD Backlight http://www.aliexpress.com/product-gs/486... (its a little bit bigger) and place (glue) in the back with wiring 2 cables to solder points in the front.
dont forget to isulate with kapton tape!
for me it works like a charm :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alistair さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 3,683
