メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
Light and Proximity Sensor not working
I have had some water damage done to my phone and used my screen (front panel) with a friend's back panel, or body, who shattered his screen. Everything is working great, but the light and proximity sensor is not working at all and I keep hitting mute with my face. I have put the #3 cable back in sever times making sure flip the clip up and down and seem to have it all of the way inserted. It seems that the only way to get the metal case over cable 3, the proximity sensor off is to remove the glass, which id like to not do. Is there anyway to do this without taking off the glass? Thanks
Update
I did have to remove the LCD screen but not the glass front; I'm not sure which one is considered the digitizer. You can gently pry the sensor housing away from the frame and replace the sensor strip.
Check out this video on YouTube:
http://www.youtube.com/watch?v=m-wjCFGW4...
Update
I was able to replace just the proximity sensor in about 30 minutes, without special tools, and for under $10. I don't feel like the whole front assembly would be much easier and costs about 10 times as much. If you don't get the proximity sensor working for some reason, then you could go ahead and get the whole front assembly, but I did not because I thought $100, was too much to spend for a small repair.
Shopping results:
http://www.google.com/products?q=iPhone+...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Hi tyler, did the proximity repair require you to remove the digitiser from the frame? or can you remove the proximity sensor leaving digitiser intact?
さんによる
コメントを追加
4件の回答
ベストアンサー
The glass can be purchased individually, but I'd suggest the frame+glass part to make things easy to deal with. It's slightly more expensive but worth it compared to bare glass.
If you need a guide to install it, this can be found here.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I would like to know how to replace the speaker assembly, on a broken iPhone screen I could take off the glass and the lcd and get it down to the bare bones and take off the case for the sensor and the small sensor strip. Is this basically the same as replacing the speak assembly? Im sorry, Im just not very clear with what that is... Thanks for the help thus far.
さんによる
Look on the internet for a guide
さんによる
So I just swapped proximity sensor cables, the number 3 cable, from another iPhone and it is all working fine and dandy. Took a little prying to get the proximity sensor housing off without bending it and just put the other in its place. All is in great working condition now.
さんによる
コメントを追加
All you have to do is pull the metal bracket off from the rear of the phone. It is the black metal bracket. I use a pick type tool to get it off without a problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You need to replace the iPhone's front panel assembly to correct this problem. This will fix the broken proximity sensor and the light sensor. It is easier than replacing just the sensors.
iPhone 3G Front Panel Assemblyの画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I did a write up to replace the ribbon, for anyone in the future that wants to attempt:
iPhone 3GS Proximity Sensor Ribbon Replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tyler さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 42,596
