メインコンテンツにスキップ
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
313回答 すべてを表示
Screen's hinges are loosened
Hello Everybody,
I'm writing this post because my screen's hinges are loosened, the screen don't close by itself but it move on its axis. I just want to know if i can tighten it. May be by tighten a screw or something, like on the DELL laptop, or I have to change the hinges?
Thanks in advance for all answers.
Best,
Arnaud
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
Apple has recognized that this is a defect. If the loose hinge gives more than an inch of play, they'll replace it for free -- even if the computer is out of warranty. Here's the link to the official Apple page on the subject: http://support.apple.com/kb/TS2948
From what I've read online, repairing it yourself is a pretty expensive proposition -- as I recall, you can't just tighten the hinge; you have to replace the whole screen.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
I have the same problem. I followed the link, spoke with apple support, then found out that this no cost repair is for MacBook Air's only.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
msjunk, it is probably best if you ask your own question. this one here seems to be a bit old (2years) and it does not look like it is visited often:-) Click on this link and give as much detail as possible. Good Luck.
さんによる
コメントを追加
usually hinges over the time get loose because the times you open and close the screen you can go to peachmac or apple store to get it tighten.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Arnaud さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 14,612
