メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
iPhone has no service after screen replacement
recently I have been repairing a few iphone 4's and have came across this problem twice now.
after replacing a screen the phone loses all service
the blue part that is often damaged seems to be fine but still get no service. could it be a problem with the gold metal but at the top of the phone? how should this sit?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
9件の回答
最も参考になった回答
Do you have the new IOS6 update???
If so, just use another phone to call your mobile. Not sure why this works but i haved now repaired 6 4s with this new update and after i repaired them they all had the searching come up, now i just call the number and it kinda like resets the reception.
hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Set the date and time manually. If you take out the battery on the iPhone (iOS 6.xx) the date will be 1970.. :p
When you have set the date and time, remove the sim card and put it back in.. This should work :)
(you kan also connect the phone to the WiFi to automatically set date and time. Do the same with the sim card, when the time is right :) )
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I curious as to the positioning of this gold metal piece also as I am having similar issues. I have a signal but only in strog areas and 3g and wifi are bouncing on and off effecting the signal. Im curious as i sat this piece in as i believe is correct but cant get a pic of it anywhere. They say there could be some grease on the attenna cable so might try cleaning this with alchol
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I also had "no service" after repairing the screen on an IPhone 4S with IOS 6.01. As stated the date and time will be 1970... After hours of headache I decided to try setting the time manually as mentioned by Alex, power off/on the phone and enter the Sim pin code again. I had low expectations, but it actually solved the problem. Afterwards, you can switch back to automatic date and time again.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I do not understand why people assume a problem is software when it has just had a hardware repair done on it. I would be willing to bet the antenna is unplugged or needs reseating.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It's an IOS6 issue. Make a full restore and you'll get the signal back after initializing it!
Hope its help
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
did this and still the same problem
さんによる
コメントを追加
There is about 7 different trouble shooting you can do.
Call the phone
Call out from the phone
set date/time
take your sim card out put someone eleses in it then put your one back in
reset phone
leave the phone alone for 10min dont touch it
Thank god for the IOS 6.0.1 that has just came out, hopfully that has fixed the bug
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
please help. I have just got an old iPhone 4 that won’t connect. it keeps saying searching and then no survive. the sim card is from the correct provider. I have updated to i0s 7 still nothing. plesseeee heelllp me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem, probably the blue signal coil has removed, i tried to bridge the two touch you can see in the picture but i destroyed the right touch as you can see in the picture again, please help me. If there is a way to make this phone work again and someone knows it i would appreciate to help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
fisher1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 11,762
