メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
20回答 すべてを表示
Please help fast: Keeps saying searching
Hello everyone,
I tried to replace my front glass, but now I've got 2 problems. My first problem is when I boot it keeps saying 'searching' for some reason. It doesn't ask my pincode for my sim card.
My second problem is.. I broke the little wifi antenna the thing where you pop it in came from the motherboard.. what can I do?
It's not my iphone please help me quick :o
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
5 件のコメント
the male connector came of the circuited board? That could most certainly explain why it is searching
さんによる
Isn't that for the wifi? so I mean the small thing which is under this thing: http://images.anandtech.com/doci/4971/4S...
How can I fix it?
さんによる
It'll help if you post an image of the actual broken part, including the board.
さんによる
You won't see anything on the picture. Though I can explain.
On the 4S you've the wifi antenna which is under the screw on this picture: http://images.anandtech.com/doci/4971/4S...
And you click the antenna ONTO the motherboard. Well, the thing where it needs to be clicked in came off the motherboard and is still attached to the antenna.
But that doesn't make any sense why its keep saying searching and doesn't popup my pincode screen..
さんによる
Does anyone know what causes this problem?
さんによる
コメントを追加
12件の回答
最も参考になった回答
I think the searching thing is a bug in iOS 6 !
Try to set the correct date/hour before insterting the SIM card !
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I tried the date/time-thing and it worked. Amazing :)
さんによる
The date/time-thing worked, thanks Christophe!
さんによる
コメントを追加
i don't think the wifi antenna makes the phone say searching.
is the iphone running iOS 6?
maybe there is something wrong with the software.
as soon as you take out the battery you'll get the searching thing.
also doesn't recognize any sim.
connect to itunes and restore
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Indeed, it doesn't ask for my pincode at all.. And it indeed runs 6.0.
This all happened after I took the phone apart.
I'm going to try a restore, sadly :p
さんによる
Worked like a charm! Though, I have to solder the WiFi connection back to the motherboard and hopefully my WiFi comes back.
さんによる
How can I accept your answer? lol
さんによる
No idea how you can accept my answer, but if think i found a solution.
Need more phones to test en be sure.
Remove the simlock code (with another phone..)
Worked on 2 phones so far
さんによる
コメントを追加
Do you have the new IOS6 update???
If so, just use another phone to call your mobile. Not sure why this works but i haved now repaired 6 4s with this new update and after i repaired them they all had the searching come up, now i just call the number and it kinda like resets the reception.
other words just call your mobile from a different phone
hope this helps
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Worked for me 2!
さんによる
コメントを追加
First of all, Reseat the upper right antenna of your iPhone which seems like pulled off little bit or has not been seated properly. Solder the antenna that came off carefully. It should work. If it solved your issue, please mark the answer as Accepted.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I too have this issue. I don't have any possibility to connect it to iTunes at the moment.
Can anyone else confirm that it helps to do a reset in iTunes?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
salam...
I am an small time independent technician.
I am not so sure about your battery problem but double check by replacing your battery or battery connector. whereas about the searching part I have been having the same problem with after replacing display assemblies for some of my customers and most of the iphones were repaired and fixed by restoring only maybe its a bug or an an apple hole for all of us to fall in or its just me.
The date and time adjustment as well as calling myself did not work for me.
Malik.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
For the date/time thing
Do not insert sim
Connect to wifi
Go to date/time settings
Turn off automatic
Set to x/x/2012
Turn on automatic
Check if it corrected date to today
Insert sim
If this doesn't work. Probably not ios 6 bug...
さんによる
コメントを追加
mine has searching on the left top corner and does not read the service i repaired the screen and the wifi is sweet and is not 6.0 but 4s
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ios 6.0 is a software version for the 3gs, 4, 4s and iphone 5
さんによる
コメントを追加
its just simple guys !!!!! i m having this problem after replacing the midle plate .....just turn off your device n than open the backcase - the battery and the last 1 is unplug the celluler antena then plug it again (this work for me after i tried all the sollution above )
sorry for my bad english at typing just share here
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I recently changed the LCD on my iphone 4S. I took a lot of care when doing this and the logic board seems to be in great condition with everything else working, inlcluding the speakers, touch screen and wifi. But I can not get any signal from the sim card even though the iphone can register the sim card details, and says no sim card installed when I take it out.
I have tried a lot of the solutions people have suggested on here. I have cleaned all the metal contacts with alcohol, made sure the connectors are properly connected (well atleast I think they are) and even bought a new antenna, a new chassis, but nothing seems to have worked.
I have realised the emergency call didnt work, so would that suggest it is an antenna issue??
Any help at this point would be really greatful.
Regards
Mark
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
That *@!#!*$ date setting keep my phone searching after update ios 6.1
Thnx everyone...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I would also like to thank Chris for his answer, but can't figure how to add under his post! My experience was a little different and may be helpful to others. The iPhone 4S of a friend needed the screen replacing and it is OS5, but the date fix worked. I have never done this before or even owned an iPhone. I followed the guide here
iPhone 4S スクリーンの交換
which is complete except it doesn't mention the front camera surround (a clear plastic ring with a bit needs to be prised off the old screen and put back in the phone body and the new screen put on from top so the surround thing doesn't fall out.
I am very meticulous and felt I did a good job, but got a continuous Searching. Telstra couldn't fix it! They did the sleep reboot and other stuff and wanted to sell a new phone! Going into settings general date&time, turning it to manual, setting it to current date & time, ejecting the sim card and reinserting it, turning airoplane mode off then on got it sorted. The last step was probably only needed to recheck as where I fixed the phone there wasn't good enough signal to pick up but going outside then turning aeroplane on & off saw it sorted.
I did as a "by the way" also connect to my wireless system before doing the above, this was just to see if that worked or not, but I was connected to wireless throughout the above procedure, doubt it is important but stating for completeness.
The unusual aspect to the above is this was an OS5 phone whereas others say it is an OS6 issue, it seems it is really a bug that has been carried on from earlier!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a iPhone 5 I woke up one morning by finding my phone saying "searching" after days before updating to 8.4 I need help did all the general resets and soft resets.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mittchel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 36,433
