メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Water-damaged iPhone 4 - Dock vs. Battery
I have a water-damaged iPhone4. I disassembled it and the logic board appears fine. When plugged into the wall, it boots to the password screen and asks for Activation. If unplugged, it immediately turns off. It doesn't connect to the computer
Questions:
1. Is it likely that it is the battery or the dock connector?
2. Why am I being asked to Activate again? Is my data gone?
3. If I need a new dock connector and/or battery, what are some trustworthy vendors?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント:
even so the logic board looks fine, I would definitely still clean it. After that, do replace the battery. One should never re-use a battery that may have had any water damage
さんによる
コメントを追加
1 件の回答
Battery issue. It is asking to activate again because the logic board is not getting enough power to "pull up" your information. Most likely after placing a new battery in the device it will work properly and all of your data will still be there. I would just buy a battery from this site.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Seth さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 455
