メインコンテンツにスキップ
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
How do I reset a frozen screen on my razr?
I was in a call, & when I tried to end it, my phone froze. Now it is stuck with the call display still showing, and it won't let me do anything. I can't turn it off, and with no battery to take out, I have no idea how to reset it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
1件のコメント
my razer cannt switch on.. only after the razer logo out then its off again.. helep helepp
さんによる
コメントを追加
13件の回答
ベストアンサー
I would suggest removing the battery for a few minutes. It's not the most difficult thing to get to.
Motorola Droid RAZR Battery Replacement
You don't need to actually remove the battery, just unplug the terminal for a few minutes.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
My phone is not working after battery replacement and stopping on Intel what I have to do please help
さんによる
コメントを追加
最も参考になった回答
My phone did the EXACT same thing. This is the fix that worked for me since the Razr doesn't allow you to take the battery out:
Hold the volume DOWN button + Power Button down at the same time for 10-15 seconds and the phone will power off. It might just restart. If it doesn't, wait 20 seconds then power it back on.
VOLUME DOWN BUTTON + POWER BUTTON held down at the same time for 10-15 seconds. This will power the phone down. Then you can turn it back on!!
このアンサーは役に立ちましたか?
スコア 25
18 件のコメント:
Thanks so much! It worked!!!
さんによる
Worked for me too! Thank you!
さんによる
It worked for me too. Thanks for this very helpful information.
さんによる
Great Advice!!!!!!!!! It worked!
さんによる
I was in a panic!! This worked!!!
さんによる
13件以上のコメントを表示
コメントを追加
Yay! Thank you for the advice of Volume Down & Power at same time for 15 seconds, it worked!!!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
yes this was the only thing that worked for me thanks.
さんによる
コメントを追加
hold volumn down + power button together worked for me to. thank you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just worked for me too! thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
don't take your battery out voids the warenty power + volum down works
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Omg you're amazing, was about to bring my droid razr into Verizon because nothing worked and it's been frozen since yesterday, but this simple trick worked! Thanks!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Does not work all of the time. First, just to get the Motorolla icon to appear can take 20 attempts. Then, most people are afraid that a complete restore will him to lose all files - does not happen with my Iphone - so he is left with turning it off, then if on again, same problem. Also, his requires to hold onto power button once green light comes on to get to any menu. Solution - get an Iphone.
さんによる
Worked great for me. It only took once, not twenty. Didn't lose any files.
さんによる
コメントを追加
wow - genius! thanks! I was about to head to Verizon also!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!I was also about to take it to verizon because nothing worked including holding down the power button...holding the volune down at the same as the power worked! Much appreciated :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I did that. But everytime I turn it back on it freezes turning on and its been like this for two days now. What do I do now.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
thumbs up !!!!!!!! bravo !!!!!!! it worked, by pushing volume down + power button at the same time. great........ mir of pakistan
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Motorola Razr is not working. When it restarts it just frozen into a Red Screen and not move forward to Home-screen and remains the same for the rest of time.
What should I do to recover it.
Thanks....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have the same problem My Motorola Droid Razr is not working. When it restarts it just frozen into a Red Screen and not move forward to Home-screen and remains the same for the rest of time.
Kindly guide....
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
susyq さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 80
今までの合計 29,088
