メインコンテンツにスキップ
The APC RS 1000 is an uninterruptible power supply capable of delivering 600 Watts.
Overload alarm lights and sound
My ups, after 5 years of continuous operation shows the overload's light .
I unplugged the PC and I replaced the battery but I have not solved the problem.
Then I opened it to see if there are components that are burned or leak but nothing.
To be sure I replaced the cooling fan but nothing has changed.
Can anyone give me some tips?
Thank you very much.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
1件のコメント
Hi, i had the same problem twice...!!!
My battery was ok, everything was ok but
the beep keep going on, for overload...
Both times i fixed doing these steps...
- Turn off the unit
- Flip over the unit
- Open the battery-cap and turn the power on
- Green Light is flashing
- Try Now (with the green light flashing) to disconnect the battery...
- Now it should be ON with the Empty battery light on (Red light)
- Connect again the battery as it is...
Now it should be ok...!!!
Good Luck...
さんによる
コメントを追加
5件の回答
ベストアンサー
Thanks to all. I have not solved the problem. I replaced the old ups with a new one.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
Roberto, If it alarms, even with nothing plugged in, then it is possible that one of the MOSFET on your mainboard has failed.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
metal–oxide–semiconductor field-effect transistor (MOSFET)
http://en.wikipedia.org/wiki/MOSFET
さんによる
Did you solve the problem? Same problem here, 4 years later..
daigoph@gmail.com
さんによる
Green light not so always yellow light and 5 Second deep alarm
さんによる
コメントを追加
- Turn off the unit
Good Luck...
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you but I replaced the old ups with a new one. Yours sincerely.
さんによる
コメントを追加
I too facing the same problem....battery charging process is fine...but when i turn on the inverter it trips and shows overload and keep continuosly beep beeps....pls help me to solve this problem....i expecting board level service suggestions ...thank you
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My problem solved with removing the all cables also power cable wait 5 minute & connect cable again it's working.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Roberto さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 12
過去 30 日: 81
今までの合計 38,784
