メインコンテンツにスキップ
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112回答 すべてを表示
締切られた回答
Increasing RAM in Samsung Galaxy tab
can I increase the RAM in Samsung Galaxy Tab from 512MB to a higher value, say 1 MB or 2MB. If yes how do I do it
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Anand, the memory is Flash NAND memory. an IC, and it is soldered onto the circuit board. It is an integrated part of your device. There is no easy way for the DIY'er to just change it. First you would have to find a higher capacity chip that fits, then you would have to make sure you solder the SMD IC onto the board. Last but not least, your firmware may not recognize the memory.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
How could Anand solder a micron board, never mind..
LoL
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 4,866
