need help: solder capacitors on logic board
My technician pulled a capacitor off my logic board that I just had repaired. What are the ID numbers for the G4 12" capacitors on the logic board so I can replace them and solder them on the board?
If you cannot find the ID you could replace with the same value and type.
このアンサーは役に立ちましたか?
Thank you. There is a number on the capacitor that gives the specs, and yes you can replace it with that number. With laptops the capacitors are miniture and so you have to measure them before you order them online - here are two places to order online:
I can order the miniature capacitors online, the lady at the electronics store told me to do it that way - but she said to be sure to measure them. Here are the websites:
www.digikey.com
www.newark.com
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 2,398
