メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
締切られた回答
Replaced front screen and now I no power
I had a bad digitizer on my iPod touch 4th generation. The touch screen did not work. I changed the screen with the digitizer and it worked for a little while. Then out of no where, the ipod went black (no power whatsoever) I opened up the iPod touch again to check all of the connections and everything seemed fine.
Has anyone ever had this problem? Everything is connected. And I also checked the battery connection and the percentage was 90% before I started working on it
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Check if itunes recognizes it. If not clean charging port with iso and charge for at least 1 hour and recheck. If nothing still try a hard reset, if nothing change battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 458
