メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1502回答 すべてを表示
Step 2 of disassembly
i have a problem in step 2 in the manual for disassembly of the iPhone 3gs iPhone 3GS Front Panel Assembly Replacement.
The problem is that I only have the glass following me up with my suction cup, not the display itself. I don't want to pry in there, but what else is there to do? The glass is only loose in the home button end and I'm not sure I can continue to take the whole glass out.
The glass have been repaired once, so I realize this must be affecting how things are with my phone.
When the glass is loose on its own like this, what can I do to get the display assembly to come up so I can exchange my battery?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Press glass back down perfect. Then using hairdryer, heat up glass so the adhesive strongly attaches to the glass again. Let it cool all the way. Then carefully try the suction cup removal.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well, that might work, but I think the job done on it seems to be dodgy. There's no other way to lift the display? Couldn't the hair dryer actually damage the phone?
I'm trying to find out if I can remove the glass without the display following up, lift the display out separately, get new adhesive for the glass, or possibly if I need to get new glass too. That's a bit expensive though. I saved $20 on the glass repair, but paying for it now instead. :-/
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Adhesive is more tacky when warm, just warm it up a bit, so you get some adhesion.
さんによる
コメントを追加
回答を追加する
MiB さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 458
