Water damage, won't power up
My Macbook Pro got water damaged, while it was in my back pack... Water had entered in on the left side of the Macbook.
The Macbook was in a vertical position in my pack, with the left side where all of the port connectors are at the bottom of the pack, my water bottle had leaked some water and the nylon laptop sleeve absorbed some of the water.
Mistake 1) When I got home I didn't realized that the water bottle had leaked, and I tried to power on the Macbook... When I pressed the power button nothing happend, I had used it earlier at work and thought I had just closed the lid, and the macbook went to sleep, and ran the battery down.
Mistake 2) I connected the power adapter to the macbook. I realized I had a problem when the green led on the magsafe connector failed to light up as usual.
When i looked at the magsafe connector port i noticed a bit of moisture on the port and edge, felt the bottom of my pack and found it was real damp, and discoved the leaking water bottle.
What I'd like opinions on... Is there a way to test the individual components.. i.e. Logic board, Magsafe DC-in board, battery to isolate what part(s) shorted out.
I have a new MBP on the way, but would like to see if I can repair my old MBP to use as a back-up or maybe give to my nephew for school.
Thanks
この質問は役に立ちましたか?
2 件のコメント
MacBook Air recovered thanks!
Kathy Thomas さんによる
So I have the same issue but I don’t understand the technological terminology. Please dumb it down for me. Thnx
QAB さんによる
