メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
No Sound From Headphone Jack
I have a 80 gb ipod 5th gen. First problem with it was it wouldn't turn on. I replaced the battery and fixed that problem. But now when i try to listen to music through the headphone jack no sound comes out. I have replaced the headphone jack but still no sound.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
khanh, if you are absolutely sure that your headphone jack is installed right and if you are using proper headphones, then there is the possibility of a bad IC. Here is part of my answer to a similar question:"here is my answer from a very similar question"this particular model has a problem with an IC on the logic board. You can try and see if you get sounds by applying some pressure to the right lower side of the iPod, almost between the click wheel and the bottom corner. Here is a forum that explains that http://discussions.apple.com/thread.jspa... and check for a posting by IPOD_wrecker. If that is happening to you there are only a couple of options. New logic board fro about $40 on eBay, reflow your old logic board or you can try what warnergt did on http://forums.macnn.com/103/ipod-iphone-... it is kind of crude but it does seem to work. The reason why it works after you place it in the fridge, is that the contraction of the metal closes the micro crack in the solder joint." Again, this is assuming your installation is correct, your headphones are working properly, the new headphone jack is working properly, and your iPod had the proper settings. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
i am sure the headphone jack is installed right because the lock button works correctly, the headphones are working correctly because i used them on another one of my ipods, and the ipod has the proper settings. i will try what warnergt did
さんによる
Sounds good, let us know how it works out for you.
さんによる
neither the heat or putting it in the freezer worked
さんによる
khanh, is there any chance that your new headphone jack is not functioning properly? Do you still have the old one to see if that makes a difference?
さんによる
i have tried both headphone jacks
さんによる
コメントを追加
回答を追加する
khanh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 2,981
