メインコンテンツにスキップ
15インチディスプレイのMacBook Proモデル
8251回答 すべてを表示
締切られた回答
keyboard and battery help
my keyboard left shift is typing symbols rather than the traditional english (or whatever) it is supposed to.. i have a macbook pro.. it has just started doing this.. so for example.. if i wanted to type the word dragons with a capital d and an exclamation point.. here is what i get..
Îragons⁄⁄ any suggestions??
also.. i am getting an X on my battery and it is showing that i have no battery available.. ideas??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Sounds like it suffered a spillage. Any possibility?
さんによる
コメントを追加
1 件の回答
ベストアンサー
If it was dropped or had something dropped on it the battery could be damaged or knocked loose... that would also likely explain the keyboard problem. If remapping the keyboard doesn't work, you'll have to open it to replace the keyboard/top case anyway so check out the battery.
Be sure to purchase the proper tools to open the machine... every job is easier when you use the proper tools.
If this answer was helpful please remember to return and mark it Accepted.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 475
