メインコンテンツにスキップ
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212回答 すべてを表示
Is second hard drive possible in with opti bay?
I have a 20" white imac with 2.0ghz core duo processor.
My question is, can I remove the optical drive and install a second hard drive with the opti bay option? I see there is an opti bay drive available but it say for core 2 duo only.
Whats the difference and what would stop it from working?
I am also upgrading the cpu to a 2.16ghz core 2 duo and was wondering if I could bump this one to 2.33ghz and what model processor would work for me?
Thank you for your time.
Oh, one more thing. What is the connection called on the optical drive? I know its not SATA.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Yes, replacing it is definitely possible. You'll need this particular enclosure that we sell. If I recall correctly, I believe the interface is Apple's proprietary IDE connector.
Follow the instructions for removing the optical drive, and before installing the optical bay enclosure, remove the plastic plate from the enclosure. You need to remove it, because it blocks some of the optical drive bracket's mounting pins.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sold4money さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,015
